Old 02-24-2010, 10:48 PM   #1
newtosupras
newtosupras is on a distinguished road
Unhappy 87 non turbo drove then died now no spark
so i jus swaped my motor out for another one ran fine was driving it 2 days later and it jus dies had it towed home i checked it and theres no spark i changed the igniter still no spark i changed the coil still no spark i changed the distributor still no spark i checked the timeing belt its good i checked the wireing with ome meter and it check out ok checked all fuses there all fine im really at a loss here and about out of money any ideas what could be wrong?????
newtosupras is offline   Reply With Quote
Old 02-25-2010, 07:10 AM   #2
Punctuation and grammar go a long way toward clearly communicating your needs... people (including me) are more likely to stop and read your post if it's a quick, easy and concise read than just skip it (like I have the past couple times I've checked in today).
Have you tested for power at the ECU? Leads B+, B1+ and BATT should all have 12v with the ignition in the on position. Check the grounds on both sides of the head; one set connects on the exhaust side near the throttle linkage assembly and the other group connect to the lower intake plenum near the starter.
Tags
no spark
my friend 90mkiii turbo has no spark supradefiant MKIII Supra 2 09-01-2006 06:27 PM
