Old 03-04-2010, 06:46 PM   #1
lacrosseg64
lacrosseg64 is on a distinguished road
Default 87 supra wont start
Got a new battery and checked the starter, but it doesnt even turn over or spark. No clue whats up and any ideas would be great
lacrosseg64 is offline   Reply With Quote
Old 03-05-2010, 12:04 AM   #2
907mge
907mge's Avatar
make sure all the connections are good, replaced a starter on my moms subaru just to find out a terminal was a little loose and not the starter
Old 03-05-2010, 05:30 PM   #3
lacrosseg64
ya ive done that already, but some of the fuses are messed up but im pretty sure its not a fuse
Old 03-06-2010, 01:35 AM   #4
907mge
907mge's Avatar
see if this can help
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Old 03-06-2010, 02:50 AM   #5
Green7mgte
Supra Forum Moderator
there has been tons of posts on this topic here on supraforums just type in No start or No spark and you will get tons of hits. go through the procedures that others have tried then get back to us =)
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 03-06-2010, 08:05 PM   #6
lacrosseg64
ok thanks for the advice
Old 03-06-2010, 09:12 PM   #7
If it's not cranking at all there are two things to check first:
1) With the ignition in the "ON" position does the Cehck Engine light turn on? It should, if it doesn't the bulb is either burned out, the ECU's pre check is failing (not sure if this results in the light remaining off though) or the ECU is not getting power.
2) Check if the starter is at least making a click sounds when you try to crank. If not, make sure the alarm is arming when you lock the car and disarming when you unlock it (try unlocking the car from the passenger door with the key.
Old 03-07-2010, 08:42 PM   #8
lacrosseg64
the check engine light dosnt turn on with the key in but it used to and the alarm has never worked for me at least. But the lock on the driver side is kinda messed up
Old 03-07-2010, 09:45 PM   #9
And what about the things in #2? Did you try locking the car with the key in the passenger door and then disarming it the same way? Does the starter click at all when you try to start the car?
I'm trying to cover the easiest things first (well, at least they're what I consider the easiest), but you need to help with the diagnosis.
Oh, and change the check engine bulb and see if it lights up with the key in the ON position... if not, then the ECU is probably not getting power.
Where you working on anything when this started?
Old 03-08-2010, 06:46 AM   #10
lacrosseg64
Naa I wasn't working on it when it started and the bulb is fine. And I thought it was the starter at first too cus it would click but not turn over or spark or anything. So I took it out and also tested the battery and replaced the battery and with the new battery it won't click or make a sound, also the sterio won't work or any of the interior electronics.
The alarm has never worked too
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
Supra won't start cmnetworx MKII Supra 2 07-31-2006 10:55 PM
supra wont start tex1116 MKIII Supra 2 10-21-2005 12:54 AM
