Old 03-06-2010, 08:02 PM   #1
sd88supra
sd88supra is on a distinguished road
Question Hood won't close
Whenever I close my hood, I don't hear nor feel the closing mechanism snap shut and it becomes annoying because the hood will open when I hit a bump. I was wondering if anyone had any issues and knew what to look for. I can't actually see what goes inside because it's closed. I may just have to put a light and a camera to see. Help appreciated.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 03-06-2010, 09:21 PM   #2
Are you familiar with how the latch operates? If so hold a screwdriver horizontally and press it down into the latch where the loop on the hood would usually enter... When the latch rotor closes behind it try to lift up... if the rotor turns freely and allows you to lift the screwdriver back out you'll need to replace the latch; if the rotor is missing the portion which is supposed to swing around and close the opening behind the screwdriver, replace the latch. If the rotor closes behind the screwdriver and does not open back up when you try to pull the screwdriver back up the inspect the loop on the hood (to ake sure it's not broken free and moving) and try lowering the hood stops a 1/4".
If you're not familiar with how the mechanism works... talk to a locksmith.
Hood release cable catawalks Non-Generation Specific Questions 11 04-24-2007 03:04 AM
HELP!!! My Hood is stuck closed!! opeth_07 Exterior , Interior, and Detailing 6 07-31-2006 06:02 PM
HELP!!! My Hood is stuck closed!! opeth_07 MKIII Supra 4 03-30-2006 12:55 PM
Got Hood Open!!!!! scruffboy Non-Generation Specific Questions 2 12-20-2005 02:03 AM
