Old 03-10-2010, 12:09 PM   #1
Chromemoly
Chromemoly is on a distinguished road
Default Lexus AFM Fitment
The answer must be simple but "search" doesn't reveal the secret easily......
I am running a K&N filter on the stock AFM housing. I am doing the Lexus/550 upgrade. I realize I am going to have to "stuff" or "force" the the Lexus housing into the accordian hose as it is larger than the stock AFM, but what K&N part# will I have to use to attach the filter to the front of the larger Lexus AFM? Should I go with an APEXi filter, what part will I need to attach the filter to the AFM?
86.5 N/A to Turbo Project
88 Turbo
69 Z/28
74 Camaro LT
87 GTI
94 EX
tungsten@cox.net
Chromemoly is offline   Reply With Quote
Old 03-11-2010, 01:48 AM   #2
I've never heard anyone say that they needed to replace the adapter. Personally, I would wait until I had the Lex AFM in hand and see if it is much different. You may find that you don't need to make any adjustments or that simply opening the bolt holes a little is all that is needed.
My preference would be either Apex'i or AEM... AEM will be less expensive and from everything I've read filters just as well if not a bit better.
Old 03-12-2010, 09:41 AM   #3
Chromemoly
Default Thanks for the response
I will try to post comparitive pics in the near future. Thanks for the links... truly helpful stuff.
88 Turbo
69 Z/28
74 Camaro LT
87 GTI
94 EX
tungsten@cox.net
Lexus AFM Questions Chromemoly MKIII Supra 0 07-05-2009 02:55 AM
Lexus AFM question? rnoswal MKIII Supra 13 04-20-2006 06:34 AM
