Old 03-12-2010, 06:34 PM   #11
btwilson86
Super Moderator
btwilson86's Avatar
Before you jump into your clutch, check for codes.
Old 03-13-2010, 02:26 AM   #12
I'm thinking fuel cut... or a knock problem... possibly both. Definitely check the codes as BT says.
Old 03-13-2010, 08:01 AM   #13
btwilson86
Super Moderator
btwilson86's Avatar
And after checking your new pics in your album, you have a hacked together vacuum system. Looks like you'll need to spend a little time and start routing your vacuum lines properly. After reading your other post, looks like Green7mgte gave you a couple of vacuum line routing diagrams
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
