hey everyone in my albums I have some pics named this is weird in them there is a pic of a little metal tube that looks like it should be hooked up to something does anybody know what this is and what it goes to thanks.
1991 Supra turbo t-61 turbo 550inj high volume fuel pump cold air intake HKS blow off valve need to ge t it tuned not sure what else it has on it. |
buddy you got some palsy. (sorry if you really do)
the lead comes from your top slot in the vsv valve on your thermostat housing. wich runs into the first slot in the throttle body. can you try and drag n drop your pics into your post? it would make it hella ezier. http://www.ma70.com/bishop92t/techtips/7mlayout1.jpg this will show you what im talking about.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
Ok here is what the guy I bought it from did man I probably have all kind of hoses in the wrong place
ok so this is most definitely wrong do you know where I can get a diagram of the right way to hook up all the vacuum lines
no idea why he would do that. Now im not saying that for your particular set up its wrong. (it seems wrong!) but I don't really know. I have seen the first connection your missing not in use on a particular set up (it was by passed or w/e) but don't ask me as to why. (car for sell section the guy with the 700hp baby blue beast)
anyhow here is a link to the tsrm vacume routing http://www.cygnusx1.net/supra/TechTi.../vacuum_2h.gif this one will help too. http://www.cygnusx1.net/Supra/Librar...spx?F=1708&P=6 good luck man. post any more questions you have.
#6 |
those go to your egr valve pickup. there shoud be two vacuum lines that come out of a little disk above your egr valve. one should say r and one should say m. there should be a diagram on your hood that explains that. i just put my throttle body back together today, shouldn't be too hard to get some vacuum lines for it.
Tube between oil pump and oil filter.... | h8z2luze | MKIII Supra | 4 | 04-19-2009 07:48 PM |
Oil in my intake tube | ClutchR1 | MKIII Supra | 2 | 10-25-2008 04:16 AM |
Vacuum tube placement? | atsomepoint | Non-Generation Specific Questions | 13 | 09-20-2007 02:02 PM |
Turbo intake tube | Reeves | MKIII Supra | 6 | 11-24-2005 08:44 AM |
