Caliper repair??
I have a Mk 3 1990 non turbo supra, but the pistons in the calipers have seized. I have got them out now but need a caliper repair kit. Any one know where I can find the rite one??
Toyota do a repair kit, the kit contains all the rubber components, seals, rubber dust covers, copper washers etc, even a sachet of lithium grease. Each kit contains enough for 2 wheels.
Rear Cylinder Kit Toyota part # 04479-14110 Front Cylinder Kit Toyota part # 04479-14100 One thing it doesn’t have is a bleed nipple/valve, Toyota part # 47547-20010 Not sure of the prices, you will need to give Toyota a call. |
You may find this useful Link the bad news is the kits are around 35.00 GB Pounds each.
Cheers for that, I'v still got the bleed nipples
