Old 03-19-2010, 01:26 AM   #1
colo288
colo288 is on a distinguished road
Default warning light that looks like a dome or filter?
I have a toyota Supra 1987 and im having a difficult time trying to figure out what the warning light that appears on my car???
it looks like a filter or dome but i have already change the air filter and the fuel filter.
any help please???
colo288 is offline   Reply With Quote
Old 03-19-2010, 01:35 AM   #2
Far left and yellow? Looks like a courthouse? That'd be a low coolant indicator. The sensor is inside the coolant reservoir. Keep an eye out for steady coolant loss as that's a common sign of a blown head gasket.
Old 03-19-2010, 01:46 AM   #3
colo288
Yea exactly. It looks like a courthouse.
So what I sould do its change the sensor right?
Thanks for replying.
Old 03-19-2010, 01:49 AM   #4
Ummm... check the coolant level? Check it when the car is cold, before the rad purges into it.
Old 03-19-2010, 02:28 AM   #5
colo288
Default warning light that looks like a courthouse?
Ol I just is and right now is empty. But I check the. Radiator and I still have coolant.
Hey about sensor where exactly is at because I just check the reservoir and the only thing I see was a small filter.
Old 03-19-2010, 02:39 AM   #6
top off your rad.. fill the overflow to the "full line"
Old 03-19-2010, 03:50 AM   #7
The Rad is not the highest point in the cooling system. Just because it looks full when you open the cap it doesn't mean the system is completely full. Do as Green says and then check the level and add more if needed after you've driven a couple times... it'll take the air a couple drives at operating temps to fully evacuate.
Old 03-19-2010, 06:53 AM   #8
colo288
Ol thats cool I'll do that.
And about sensor where exactly can i find it, because I check the reservoir and the the only thing I see is the siphon filter.
Old 03-19-2010, 07:05 AM   #9
colo288
And about sensor where exactly can i find it, because I check the reservoir and the the only thing I see is the syphon filter.
Old 03-19-2010, 07:14 AM   #10
The sensor is at the very bottom of the reservoir. If you look at the outside, you should see a connector with a couple of wires leading to the bottom of the tank. That is your sensor
Dome Light? SuperX MKIII Supra 4 02-02-2010 11:49 PM
Brake Warning Light on dash!... *D-Joker* MKIII Supra 6 08-28-2009 12:53 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
