warning light that looks like a dome or filter?
I have a toyota Supra 1987 and im having a difficult time trying to figure out what the warning light that appears on my car???
it looks like a filter or dome but i have already change the air filter and the fuel filter. any help please??? |
Far left and yellow? Looks like a courthouse? That'd be a low coolant indicator. The sensor is inside the coolant reservoir. Keep an eye out for steady coolant loss as that's a common sign of a blown head gasket.
Yea exactly. It looks like a courthouse.
So what I sould do its change the sensor right? Thanks for replying. |
Ummm... check the coolant level? Check it when the car is cold, before the rad purges into it.
warning light that looks like a courthouse?
Ol I just is and right now is empty. But I check the. Radiator and I still have coolant.
Hey about sensor where exactly is at because I just check the reservoir and the only thing I see was a small filter. |
top off your rad.. fill the overflow to the "full line"
The Rad is not the highest point in the cooling system. Just because it looks full when you open the cap it doesn't mean the system is completely full. Do as Green says and then check the level and add more if needed after you've driven a couple times... it'll take the air a couple drives at operating temps to fully evacuate.
Ol thats cool I'll do that.
And about sensor where exactly can i find it, because I check the reservoir and the the only thing I see is the siphon filter. |
And about sensor where exactly can i find it, because I check the reservoir and the the only thing I see is the syphon filter. |
The sensor is at the very bottom of the reservoir. If you look at the outside, you should see a connector with a couple of wires leading to the bottom of the tank. That is your sensor
thanks for replying btwilson86.
would a 90s model engine fit on my toyota supra turbo 1987??? |
There are a few differences between the two, off the top of my head I know the oil pans, oil pump sump, fuel injectors, redline, and I'm sure other things are different. And that's if you're going from 87 turbo engine to 90 turbo engine. If you go from N/A to turbo, there's obviously going to be more differences.
So yes, it will fit. There will just be several changes that you need to make for it to work |
