#4 |
AEM EMS
The design of the metal pipe is used on left hand drive and right hand drive vehicles. On left hand drive as btwilson86 said it should be blanked off with a rubber cap or on later models metal cap. On a right hand drive Supra that end of the pipe is used to connect to the heater matrix via the firewall and the cap is used on the metal pipe on the right of the diagram. In other words all the connections are swapped around depending if its right hand or left hand drive.
MK3 supra Hose Techniques silicon hoses | Micahwc | Shops & Part Reviews | 8 | 12-09-2012 09:03 PM |
couple of questions about my 7MGE motor | SDK | MKIII Supra | 2 | 12-13-2009 07:26 AM |
Sm Vac Hose Under Accordian Hose | Chromemoly | MKIII Supra | 3 | 07-03-2009 01:19 AM |
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) | Grandavi | MKIII Supra | 2 | 09-29-2008 04:49 AM |
Plug or hose came off back of block | f00g00 | MKIII Supra | 3 | 05-20-2006 11:01 PM |
