Old 03-23-2010, 07:29 AM   #1
MarkLinRacing
MarkLinRacing's Avatar
MarkLinRacing is on a distinguished road
Default Knock Sensor/Wiring
So I have my CEL light on.
Pulled the diagnosis code and said something about knock sensor or possibly knock sensor wiring.
I heard from a friend that previously owned a MKIII Supra that apparently these knock sensors on the 7MGTE like to crap out.
I don't want to fix it unless it's causing an issue, currently the car under load, off load and at idle.
Another friend mentioned that my car might be slower than it actually is because the car might be running in "safe mode" because it won't know if it's experiencing knock or not.
I'm not familiar with how these ECUS are programmed. I would appreciate any insight.
Thanks!
MarkLinRacing is offline   Reply With Quote
Old 03-23-2010, 12:42 PM   #2
Our knock sensors are pretty robust actually. More often than not the code 52 issue is due to wiring. Search "knock sensor rewire"... and yes, it can make the car run like piss depending on just how bad it is.
Old 03-23-2010, 02:52 PM   #3
MarkLinRacing
Thanks, I found a thread about knock sensor/rewiring.
I should've searched first..
Tags
cel, knock sensor, mkiii supra, pinging, wiring
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
