Old 03-26-2010, 01:46 AM   #11
SDK
SDK is an unknown quantity at this point
checked my temp sensor and it is fine. also when the car idles and just sits there the idle is 780 and moisture out the back. never really stops.
SDK is offline   Reply With Quote
Old 04-09-2010, 04:39 PM   #12
SDK
So i clocked my distributer up and I set my throttle higher and I received the exact same score. Give or take 2 points. Could this be a bad cat? It ran for a while with the head blown, because I have now had it tested with the engine set 3 different ways and received the exact same score. This is confusing the hell out of me.
Shane
Old 04-16-2010, 12:15 AM   #13
The advance timing is controlled by the ECU. Manually adjusting the timing only affects the system in a few circumstances. Find and fix the problem, there's no cheat.
Have you checked your spark plugs?
Old 04-18-2010, 04:17 AM   #14
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
Yeah check the plugs for sure. Fix that damn idle, take it to someone who can tell you what it is. When you get the idle fixed let me know because there is a cheat.... THERE IS ALWAYS A CHEAT!
Your choice but this is what I put in mine after doubling the standards at emmissions. On half a talk I poured a bottle of rubbing alcohol in the tank. ZIP!!!!! PRESTO!!!!!!! Alcohol is unlike gas in the fact that it burns pure and complete leaving no unburned and impure gas behind. Better suggestion yet...... when you are almost out of gas completely run A COUPLE GALLONS OF DE-NATURED ALCOHOL
Thanks for you time ladies and gentlemen....class dismissed!
hahaha j/k always wanted to say that anyway let me know how the works for ya!
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
AlexSchuSupra is offline   Reply With Quote
Old 04-18-2010, 05:17 AM   #15
<sigh> there's always got to be one...
It takes a whole lot more than one bottle of rubbing alcohol (30% of which is usually water, BTW) to affect the octane rating of the fuel already in your tank. It takes 10 time that amount to affect the hydrocarbon content. By the time you reach the required volume you've upset the volumetric proportioning required to burn alcohol at a SAFE temperature. Alcohol requires approximately 25% more fuel versus gasoline for a cool and stoichiometric burn.... if you're into placebos go for it.... like burned vales go for it.. I don't care, just don't post utter bullshit on the forum.
If you're not passing emissions it's because SOMETHING IS BROKEN!!! FIX IT.
emissions FYI ddmcse MKIII Supra 0 02-01-2008 12:34 PM
Went through Emissions today.... IHateHacks MKIII Supra 32 07-03-2007 07:31 PM
Emissions gorillaguy8 MKIII Supra 10 04-10-2007 12:33 AM
Emissions drmmr15 MKIII Supra 1 01-19-2007 04:09 PM
Emissions? Luvs2slide MKIII Supra 3 06-03-2006 11:55 AM
