Old 03-24-2010, 04:19 AM   #1
2genfun
2genfun is on a distinguished road
Default dead spot in throttle...
so from about 1900-2400rpm i have this dead spot in the throttle like it wants to shut off...it acts like a honda with a bad idle air control. It'll rev fine but if ur just cruisin within that rpm range its B.... cuz it keeps engaging and disengaging the throttle...Im replacing the cap and rotor tomorrow its got new plugs and wires already...anything else im missing? maf,cam sensor, distributor?
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 03-24-2010, 09:21 PM   #2
TripleC
TripleC's Avatar
Set the gap on your plugs so you know that they are all the same
Old 03-25-2010, 12:43 AM   #3
2genfun
already did...so the new cap and rotor didnt help really...anything else...i fixed the tps sensor so im all ears!
Old 03-25-2010, 02:19 AM   #4
Have you actually tested the signal from the TPS? Test the voltage coming from Vs, should be around .5 closed, 3.5 full open and should sweep steadily between.
grumble...... Post more info about your car, add it to your profile or better yet put it in your sig........ /grumble
Where was I...
Is this a GE or a GTE?
Old 03-25-2010, 02:49 AM   #5
2genfun
its a stock 7mge...no havent tested it yet...so vs to ground im guessing?
Old 03-26-2010, 12:25 AM   #6
Yeah, to ground... the TPS signal line it VTA, not Vs... I had already moved ahead in my head with the other big possibility:
With a N/A the problem is more likely to be a flat spot in the VAFM's Potentiometer. Test pin Vs there for consistent voltage while opening the vane.
Test both though, they are both wear components... no idea why everyone buys used ones, they do have a limited lifespan.
Old 03-27-2010, 01:18 PM   #7
2genfun
so guess what i did...i was testing the afm and found that it was bad. Then like a curious cat i decided to pull the actual sensor out. Didnt know it was connected by short wires and pulled two of the circuits clean off the circuit board...So now the car wont start. Anybody have an extra afm for sale or anything. i dont feel like paying 130 for a new one and a four day wait
Old 03-27-2010, 03:05 PM   #8
get your self over to supra mania stat and check out there for sale forum.
I see them there all the time. mostly for turbo's tho. but you might get lucky.
Old 03-28-2010, 11:37 PM   #9
2genfun
oh well had to resort to advanced...
no throttle in gear weol66 Non-Generation Specific Questions 0 07-26-2008 01:04 PM
lost of power at full throttle?? peedamonkee MKII Supra 4 01-08-2008 05:50 AM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
Throttle response f00g00 MKIII Supra 1 04-13-2006 12:57 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
