Old 03-25-2010, 05:04 AM   #1
scaggsj
scaggsj's Avatar
Default Coolant plugs?
I did a search but didnt find what I was looking for so I just put this out there knowing its been anwsered somewhere. I have an 87 7mge auto recently replaced headgasket and the stuff that goes with it. I didnt change the coolant plugs or #3 gasket. This is where Im starting to think I messed up. Cars been running fine but has been losing coolant, its been winter and the only smoke I see seems normal. (Im also running real rich you can smell it) So losing coolant at a slow pace didnt seem to be affecting power or causeing misses, then more recently the loss has gotten worse but still not bad but now its missing. I you get it above 1000 rpms it seems to run alright, again im having air fuel problems. No oil in coolant that I can see and no coolant getting in oil. How do I know if its the coolant plugs and how do if its the passages. I read something about that on one of cres posts.
1987 Supra 7MGE - Auto - Stock - White
Previoius Toyotas;
1992 Toyota Celica Gt, (Sold)
1988 Toyota Celica Alltrac Turbo (Died)
Old 03-27-2010, 04:10 PM   #2
scaggsj
scaggsj's Avatar
bump
Wondering if anyone knows whats involved in changeing coolant plugs.
Previoius Toyotas;
Old 03-27-2010, 05:34 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Not something I've done, a few links that may help Link ,Link and Link when searching, use the words "freeze plug".
Old 03-27-2010, 10:59 PM   #4
scaggsj
scaggsj's Avatar
Thanks Bill but I think we must be atlking about two differant things. The freeze plugs are on the side of the engine the plugs Im talking about are on the head. in between the spark plugs in between the valve covers
Previoius Toyotas;
Old 03-28-2010, 01:08 AM   #5
907mge
907mge's Avatar
You are talking about the 3 plugs between the spark plug holes, because if you are I was working on mine today and was not able to get them out.
I asked at toyota and they said to use a big breaker bar but I had no luck with that so I put rtv on top of the plugs for now. I may try again when the head is back on.
Old 03-30-2010, 03:01 AM   #6
scaggsj
scaggsj's Avatar
Yes those are the plugs, anyone have a little light on the subject?
Previoius Toyotas;
Old 03-30-2010, 07:52 AM   #7
reydio
reydio is on a distinguished road
Those plugs are not in anyway connected to the coolant passages, they are oil passages from valve cover to valve cover. You will need a large allen head type socket. When you remove the #3 gasket, you can either replace it or use washers to seal them off. I think Napa carries the large brass washers. Or you can use Toyota FIPG or Honda Bond to seal them. The #3 gasket helps keep the debris from falling in the valley. Since I clean mine every so often, I decided not to replace the #3 gasket. So far no oil leak for over a year already.
As for your other problems, are you getting any engine codes? Also check your radiator cap, replace if you have not replace it yet. For missing, check your plugs, rotor and cap.
Good Luck!!
reydio is offline   Reply With Quote
Old 03-30-2010, 11:00 AM   #8
907mge
907mge's Avatar
not the top plugs, the ones lower between the spark plug holes
Old 03-30-2010, 10:43 PM   #9
scaggsj
scaggsj's Avatar
Ive got a new radiator cap, hoses, I flushed the coolant system after the hg repair, new water pump, new thermostat, Im def burning water, hince the miss over 1000 rpms no miss only at idle, the smoke from burning water goes away above a grand as well. Im getting coolant in the combustion chamber but not in the oil and no oil in water.
Previoius Toyotas;
Old 03-31-2010, 12:47 AM   #10
Green7mgte
Supra Forum Moderator
is it cold only missfire?
The leak may occur only as the engine cools down alter it's shut down, or it may be continuous. Either way, the leaking coolant enters the combustion chamber while the engine is off. This fouls the spark plug, causing the misfire during the engine's first cold start. Once the plug has a chance to clear itself and begin firing, the misfire goes away, but not before the misfire code is stored. If any more coolant continues to leak as the engine warms up, it's burned because the plug is no longer fouled.
I would suggest renting a rad pressure tester or go buy one for 60 bucks from harbor freight. pressure the rad system according to the psi on the rad cap (13 max) and see what sprays!
good luck
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Coolant on top of spark plugs suprajim MKIII Supra 3 03-24-2010 03:49 AM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
coolant plugs suck balls tone loc MKIII Supra 4 08-13-2006 09:29 PM
