Old 03-31-2010, 08:21 PM   #1
GettaRobo
GettaRobo is on a distinguished road
Default Acceleration issue
I've been having an issue with acceleration since I bought my 88 NA last January. It more or less runs fine up until 4k RPM's (perhaps a bit sluggish even) and then it won't go past WOT or otherwise. I'm getting black smoke out of the tailpipe too from what I understand is from too much fuel. The isn't normally black unless you pin it, but it definitely smells rich at idle. What has been done/checked: sparkplugs twice, coil wire, MAF has been replaced, tuneup has been done twice, TPS has been adjusted and replaced. As far as I know there are no holes in the intake, but I'm not 100% sure. Only one error code displays, but it is for the speed sensor in the transmission (another problem which deserves it's own thread in itself.) There is also a possibility of a vacuum leak as I can hear something sucking air when I turn the car off. I'm wondering if anyone has some insight with this problem.
GettaRobo is offline   Reply With Quote
94 Supra TT with idling and lost of power issue bayatt MKIV Supra 4 03-12-2010 01:29 PM
Wrist pin issue -- Was: Ris pen issue KeelanWiese MKIII Supra 3 02-13-2010 07:38 PM
Sputtering Issue gorillaguy8 MKIII Supra 5 02-02-2010 09:52 PM
Rough Idle Issue suprajim MKIII Supra 9 12-19-2009 10:35 PM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
