Old 04-04-2010, 10:17 PM   #1
connormcd88MKIII
connormcd88MKIII is on a distinguished road
Default Rough block deck...
Now I have a picture of my number six cylinder and it seems to be slightly roughed up. It seems minor but I want to make sure that there wont be a leak. Do you guys think it will be a problem? What are my possible solutions?[IMG]P4030699.JPG[/IMG]
connormcd88MKIII is offline   Reply With Quote
Old 04-05-2010, 01:18 AM   #2
I'd get the block machined.
Old 04-05-2010, 02:17 AM   #3
Green7mgte
Supra Forum Moderator
cre, can you say why you recommend machining the block? what from the picture did you discern, that warranted machining.
just curious.
thanks.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-05-2010, 05:12 AM   #4
Always hard to tell from a picture, but the erosion between the cylinder bore and the water jacket are enough to stop me from just slapping it all back together. Overall though the surface isn't clean enough IMO, the indentions from the rings, the pits from the former HG, scratches.... and so on.
Connor, were you loosing coolant or did the coolant have an excessively high pH before you pulled the head off or before the HG blew (if it did ever blow in a big way)? As clean as that piston is compared to #5 it's been seeing a fair amount of water.
Old 04-05-2010, 06:30 AM   #5
connormcd88MKIII
I was losing coolant... Heres also a picture of the old head gasket. And if I were to get it resurfaced to correct the pitting, would I need to make any modifications to the pistons, rods, bearings etc., to account for the loss of the material for the block?
Old 04-08-2010, 03:58 PM   #6
MA70-3.0GT
MA70-3.0GT's Avatar
Sorry to say this, but as far as I can tell from the pic what appears to have happened is the previous HG (guessing it was done fairly recently) went in the same area & somebody was a bit over zealous with the cleanup of the affected area. TBH it looks from the photo as if it's been hit with fairly heavy sandpaper or wire wool... And then the resulting block warpage has given the effect we see here with the next HG.
I'd have to agree with cre that machining is the only sure way to make sure it's within warpage tolerance, the head may also need skimming now if that's in a similar state. As to modifications after a skim, it depends on how much material is removed & I can't think of the specs off hand but it's in the tsrm anyway & if both head & block come within the tolerances after skimming then you don't need to do a thing.
However if (as usual, as the factory tolerances are tight-ish) there is too much material gone for a stock HG you can go for a thicker metal HG to take up the difference, you'll need to look into head/deck finishes for that route though as they have to be mirror like... IMO best have the pair finished to MHG surface roughness specs from the get go & then if you find you can get away with a stock item (if you really wanna by then!) fair enough, but if not you're not stuck then with running back to the machine shop for more sessions & more material/not to mention cash, lost...
Old 05-23-2010, 04:28 PM   #7
connormcd88MKIII
Default starting it up
So I finally finished working yesterday and it was time to attempt to start it. It started up after only a couple of seconds and it seemed fine. Then I noticed a a bit of white smoke coming from where the exhaust manifold meets the exhaust. Any ideas on what may be the problem?
Old 05-24-2010, 02:09 AM   #8
Green7mgte
did you strip any of the exhaust bolts?
Supra FAQ
Supra MKIII FAQ
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
decking block, reuse most parts. jvginpdx MKIII Supra 0 08-18-2009 07:03 PM
prepping block for headgasket question dannydavi MKIII Supra 1 12-06-2008 07:44 AM
