Old 04-05-2010, 02:10 PM   #1
fasteddy5000
fasteddy5000 is on a distinguished road
Default Interior smell
When I turn on the heater or just the vents I get a moldy type smell that leaves me congested. I fell like my car is slowly killing me. I have a 1990 non turbo. I just did the head gasket along with all new hoses. I'm not losing coolant any more or overheating but the smell continues. Are there any interior filters I can change or anything in the fan assembly to change. Thanks, Ed.
fasteddy5000 is offline   Reply With Quote
Old 04-06-2010, 05:55 PM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
if anything, you have mold near the evaporator from the condensation runoff. check the carpet under the dash, then think about takin the HVAC system apart to clean it out to get rid of the smell.
Or cover it up, cause that'll be easier.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 04-06-2010, 10:30 PM   #3
i broke into my buddys car once and put salmon steaks under his seats. in his glove box, under his hood.
watching him come outa the movie theater with his g/f and flip out was excellent. I should post the video If I can dig it out.
Old 07-05-2010, 09:32 PM   #4
batmmannn
batmmannn's Avatar
Default Dead rats
Probably a mouse got in there and died. Check that out!
Old 07-06-2010, 02:09 PM   #5
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
I believe that the company Ozium ( also makes air freshener ) has a product for removing mold out of the vents that you just spray. When I worked at Oreillys 4 months ago they had it hanging on a sidecap near the A/c recharge stuff. Comes in about a 4 oz. spray can, try that and see if it helps...
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
