Old 04-09-2010, 04:51 PM   #1
bryanf89
Default Starter issues! Please help
My supra doesn't deliever power to the starter, only sometimes. People told me it could be the alarm i installed, but i started the car before while the alarm was on. This is my 3rd starter which is an original toyota starter. What electrical problem im i dealing with, can it be the starter switch, fuses, or wiring? All the fuses are intact.
Old 04-09-2010, 11:31 PM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
If your fuses are good, the next step is to check any switches between the key and the starter. So the ignition switch, clutch switch(manual), and the start solenoid. Otherwise if all those are good, you've either got a bad starter or the alarm is in fact, getting in the way.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 04-10-2010, 01:44 AM   #3
He's also got a flashing OD light... I'm thinking he's got a bad NSW (Neutral Start Switch).
Bryan, keeping your problems in the same thread will help people figure out if there's a common cause. A bad NSW will cause error codes, prevent the car from starting AND mess up your idle.... as well as other neato stuff.
Old 04-10-2010, 03:25 AM   #4
bryanf89
I dont have the check engine light o the od light on. If i kick start the car, it idles and purrs like a kitten. Im goin to test the wiring and switches on the car. My last resort will be a direct connect.
Old 04-10-2010, 05:43 AM   #5
Sorry, my bad.... another person was talking about the OD and I thought it was you... Obviously not as Manual transmissions don't have an OD light.
The alarm is a common cause followed by a bad clutch start switch (on the floorboard/firewall where the clutch pedal arm presses it when it swings down. I would start with those and testing to see if any voltage is reaching the small solenoid wire at the starter.
89 Supra Starter Issue, anyone with pictures? destro MKIII Supra 7 05-09-2010 09:13 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
starter removel? swied MKIII Supra 4 04-23-2007 04:50 AM
