#1 |
I took my car to the garage yesterday for a check-up. Basically just needed to check out the fuel pressure regulator and have the wideband recalibrated. All went well. When i got close to home, the dach lights came on (Just the battery light, tail light symbol, and hand brake symbol), the Air/Fuel went crazy lean, and the idle droped and ran kind of rough. The problem comes and goes, sometimes quickly and sometimes it stays for a bit. Any ideas? It's a brain buster! I think it might be the ground for the battery, or the alternator going bad, or a problem with an injector. The problem just happened out of nowhere, everything was fine, and then....
ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
electrical problem! I think!!!!!help!! | Boostcrazy61 | MKII Supra | 0 | 08-21-2009 12:08 AM |
Nissan Sentra Tranny problem. | redmaro | Off Topic Forum | 2 | 11-28-2006 01:58 PM |
tsp problem for na t supra | jdlee123 | MKIV Supra | 0 | 09-02-2005 06:01 PM |
