#1 |
![]() Toyota Racing Development Join Date: Apr 2007
The white material is most likely HG "fix" additive.
Get the gasket from Toyota... I don't think you'll find it separate from a full gasket set any other way.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#2 |
Well i am not opposed to getting a full gasket set but there are so many lol where would you recommend getting it from and what exactly would the set be called
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive. |
#3 |
Super Moderator
The gasket that I think you're looking for is the throttle body base gasket. IIRC, on the turbo models that's what bolts up to the upper intake plenum.
From what I can find online it looks like that gasket is Toyota Part 22271-42040
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#4 |
For 95% of the gaskets any make will do just fine. The kit from this eBay seller is rather popular though and inexpensive: http://cgi.ebay.com/ebaymotors/86-93...Q5fAccessories
I wouldn't trust the included HG much, but I've read it's built like Toyota's.
#5 | |
![]() Quote:
I just got a supra turbo i need help please!!! | bradenman1 | MKIII Supra | 145 | 10-17-2010 02:42 AM |
1990 supra turbo | Rob1 | MKIII Supra | 3 | 03-31-2010 05:00 PM |
88 supra non turbo clutch/idle problem? | 88SupraQ | Non-Generation Specific Questions | 1 | 05-03-2009 02:31 AM |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
