Old 04-12-2010, 01:14 AM   #1
907mge
907mge's Avatar
Default HG Install help
I insatalled the head without puting the seal packing between the head and block in the two places at the front. Is it worth taking it back off to put it in? Also which direction do the cam seals go at the front?
Old 04-12-2010, 01:49 AM   #2
Yes, the packing is a must.
The seals go in with the solid face facing out or forward. If you look at the seals there are also arrows showing the direction of cam rotation. But the solid face faces front and the hollow faces in.
Old 04-12-2010, 02:02 AM   #3
907mge
907mge's Avatar
so if I take the head back off I guess I will need a new head gasket?
Old 04-12-2010, 02:03 AM   #4
If it's an OEM type (aka composite) then yes.
Old 04-12-2010, 02:14 AM   #5
907mge
907mge's Avatar
Also, is there anything I should put on the gasket? I heard of some who use some sort of copper spray.
Old 04-12-2010, 04:35 AM   #6
That depends entirely on the type of gasket. The only dressing that's safe to use in all cases is Hylomar's "free" dressing. If you know for sure that the gasket has no dressings already on it you may use Permatex copper gasket dressing or Hylomar blue or aerosol gasket dressing. The OEM composite HG is not coated, but aftermarket gaskets may be. Personally, I think you can get away with dressings on just about any HG as long as you only put on a thin coat, do it in a couple layers and give each layer a couple minutes for the solvents to escape.
Old 04-12-2010, 10:27 AM   #7
907mge
907mge's Avatar
If I can't find either chemical would I be ok without dressing?It doesen't say anything about dressing in TSRM but then again the torque is well off that much I do know. It's a felro hg since thats whats on it now and it will take too long to get a toyota one.
Old 04-12-2010, 01:04 PM   #8
With a composite gasket (Felpro or Toyota) I'd use dressing. You shouldn't have any trouble at all finding the Permatex spray.
Old 04-12-2010, 03:08 PM   #9
just to further this discussion what is the purpose and benefits of applying a dressing to your HG?
allowing a better seal? and possible prevention of "weak seals?"
Old 04-13-2010, 12:43 AM   #10
There are a few purposes. Proper dressings don't dry or solidify like paint does (hence the reason I've NEVER understood why some people say to "just use silver spray paint")... it's also tacky (see: better adhesion) and serves as a dielectric buffer. I've also heard some say that it promotes heat transfer but I've yet to hear how it could possibly make any significant difference.
anyone install aftermarket stereo? dannydavi Car Audio and Alarms 10 03-17-2012 10:41 PM
Boost gauge install location Durandal MKIV Supra 1 07-26-2009 11:55 AM
water temp gauge install sundevil1 MKIII Supra 3 12-09-2008 04:38 PM
How to install a oil temp controller ? Supra-Iceman Non-Generation Specific Questions 4 01-30-2007 11:18 PM
hks TT install mizuboi MKIII Supra 11 11-17-2006 03:04 AM
