Old 04-12-2010, 02:54 AM   #1
Bloody Ben
Bloody Ben is on a distinguished road
Default Killing my power antenna
I only really use my ipod fm transmitter so I'm thinking it would still work fine if I just went in and cut the power for the antenna. I just don't like hearing it all the time, not to mention it's kinda ugly. So does anyone have any thought on potential problems or has anyone else done this?
Bloody Ben is offline   Reply With Quote
Old 04-12-2010, 03:45 AM   #2
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
I did the same thing for a while, just because it was so annoying and I only listened to cd's. And it worked just fine, and would even still get most stations. And now I don't have a radio or anything and no longer have an antenna.
1988 supra turbo. In process of modding:Roll cage, seats, dp, 3" intercooler, fuel upgrades, and turbo upgrades next.
tak2099 is offline   Reply With Quote
Old 04-12-2010, 04:45 AM   #3
Meh, just put a switch on the signal line from the radio to the antenna.... that way if you just feel like it you can switch the antenna on and listen to the radio.
Old 04-12-2010, 03:17 PM   #4
Green7mgte
Supra Forum Moderator
on the subject of antennas. my mother hung a June beetle bag from the antenna of the supra before it was in my possession. along came a summer storm and the 10 lb bag of dead june beetles snapped that antenna like a twig. I essentially just pulled the remainder out and plugged the hole. first by shoving something rubber and small down inside the hole then prying the remaining metal down. and then topped the hole thing with piece of plastic gasket. can't even tell its not suppose to be there.. I use my sirus radio all the time so apart from the 3 second antenna sound when i turn my radio on I have no problems. Ill probably install a new one eventually. I like things stock
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-13-2010, 12:20 AM   #5
tak2099
tak2099's Avatar
The switch is a good idea! And man, that is nasty......and out of the ordinary.
power antenna 95SupraN\A MKIV Supra 1 02-27-2006 10:14 PM
87 Supra Power antenna wiring colors scrid Non-Generation Specific Questions 2 10-03-2005 01:30 AM
