Old 04-17-2010, 04:45 PM   #11
btwilson86
Super Moderator
btwilson86's Avatar
Pulling the engine on these cars is fairly straightforward. You can leave it almost fully assembled if you pull the wiring harness with the engine. All you have to do is remove your glovebox, unplug the harness from the ECU, and push the wires and the grommet out through the firewall into the engine bay. Then just find the couple of connectors that go to body electronics, and you're good to go.
IMO, it's easiest to pull the transmission with the engine. Helps maintain the proper angle when removing it from the car, and then you don't have to deal with the PITA bolts at the top of the bellhousing.
And one last thing, remove your hood! First time I didn't think it through and halfway through the process I had to stop to get that thing out of the way
Old 04-17-2010, 05:16 PM   #12
Chasing the threads is easy. Just do it when you've got some energy and patience left. What you want is an "Intermediate" or "taper" type. I'll dig up the size when I have a moment. The only real trick is keeping the tap VERY well lubed and cleaning out the hole frequently (especially important with a block that hasn't had the threads chased in a long time). So, you take head off and clean out the bolt hole thoroughly, lube the tap with some lightweight motor oil, start threading the tap in (getting it started is the tricky part, DO NOT LET IT MISTHREAD!!!!!!!!!!!), then slowly and steadily thread the tap in half way or so. Now remove and clean the tap and finish threading it into the bolt hole. Remove the tap, clean it and the hole out thoroughly and thread the tap back into the hole and chase it the whole way to be sure everything is smooth. Remove the tap, clean out the hole and tap again and move on to the next.
When I say the manufacturer's specs I meant the manufacturer of the fastener... not the car. ARP specifies 75ft lbs for 7M head bolts and 90ft lbs for 7M head studs.
By the way, there is actually a difference between a "chase" and a "tap". A chase is generally a little undersized and doesn't cut the block material as much. These are intended to correct misshapen threads. Taps are intended for cutting new threads into a material. The difference with a cast iron block isn't a critical one, although I think with an aluminum block a tap in place of a chase would be a big no-no.
Old 04-17-2010, 09:38 PM   #13
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
ok so maybe that will be a better option than getting it down to the block and then removing it. either way i will be taking the tranny out at the same time then swapping in the r154. and yea i cant imagine pulling the engine with the good still on.
lol oh man. ive used a tap and dye before is this somewhat the same? and once i tap the holes i wont need bigger size bolts? and how much resistance should i be feeling when i do this? wow so many questions. where can i buy this and how long does it need to be? and should i apply rtv to my bolts when i install them? thanks for all the info. my patience has greatly improved from this car. im actually excited to hack at this more with the tranny coming in. i also want to upgrade the suspension like we talked about earlier with bushings, shocks and springs. ill also be prepping the interior.im working locally so transportation isnt a must anymore.
thanks again
cvbikeguy is offline   Reply With Quote
Old 04-18-2010, 04:22 PM   #14
man i love reading all your threads thanks for the knowledge!!!
Old 04-18-2010, 04:57 PM   #15
No, you'll use the stock size bolts. You're not tapping the holes any larger, you're tapping at their current size to just clear out material which has swelled and to reshape them so that the bolts can go in without any resistance which would skew the torque readings.
Make sure to THOROUGHLY lubricate the bolt threads with a good moly based lube. If you used moly lube prior (you should have, if you didn't there's major mistake #2) you can soften it up by massaging a little oil into it, but I'dd add some fresh grease too.
tighten in the correct order in multiple passes. I generally torque in 15 to 20 ft lb increments. First pass @ 30, second @ 45, third @ 60, fourth at 75. If I'm using studs I'll do it that way up to 90 (did last night in fact).
The tap length doesn't matter, but they're fairly standard. You want one the same size and pitch of the stock head bolts. A bottoming tap is even better but they're a lot more expensive. Unlike a taper they'll cut evenly all the way to the bottom, but it isn't critical here.
Buy or borrow or rent a machinist's straight edge and check the block and head for warpage as shown in the TSRM. Make sure the lower rear timing plate's deck does NOT sit any higher than the block's deck!!!! If it does it will keep the head from coming down all the way and evenly.
Absolutely not!
Old 04-18-2010, 05:12 PM   #16
Wikipedia has some good info on the different types and how they work.
http://en.wikipedia.org/wiki/Taps_and_dies
Old 04-18-2010, 07:29 PM   #17
cvbikeguy
cvbikeguy's Avatar
lol its nice to know my pain and struggles can be of service to someone else .
id rather post all my problems to help others that are going through the same thing. once i start hacking away ill post up picks. ill also do that for when the interior comes out (i think im just walking into trouble) hope
Old 04-18-2010, 07:32 PM   #18
cvbikeguy
cvbikeguy's Avatar
Absolutely not!
moly and grease on the threads?
wow im sorry to say that i failed to check that. wiki is my middle name
thanks cre. who knows possibly in a couple months i can actually get this running
Old 04-25-2010, 03:56 AM   #19
http://store.driftmotion.com/static/i-tap12x125.php
As for the moly thing... torque values vary depending on the type of lubricant used. Where a fastener may only require 90ft lbs with a good moly used to luge the threads it may require as much as 130ft lbs if only lubed with 30 weight oil.
Old 04-26-2010, 12:12 PM   #20
MA70-3.0GT
MA70-3.0GT's Avatar
Damn sorry to hear this man, I'd just cry. (I'm pissed off enough just having an oil leak from the turbo after reassembly!!!) think it's pretty much been covered here in that the threads need to be as clean as the rest of the job really if it's gonna hold. I cleaned mine with a combo of 2 stroke oil & an old bolt with slots cut up the length of the thread in the same fashion as a bottoming tap but obviously with the small advantage of only removing crap not fresh iron) & after that blasted them out thoroughly with brake cleaner until a rag on a screwdriver came out of each hole clean. Also I took a clean bolt & made sure it went in by hand with the same force, right to the bottom of each hole with no sticky bits. Then plugged the holes with blue roll until I was ready to throw the head on. In short the holes need to be good for eating your dinner off & then some.
Also if you're reusing bolts after any time or a HG blow make sure (ideally with a die nut) that the threads on those are perfect too. As cre mentioned you wouldn't believe how little crap or even just a different lube can affect torque readings opposed to clamping force...
Oh one more thing I didn't notice mentioned was the dowels front and back, their holes also need to be clean & the surface of the dowel perfect or the head could potentially stick on those. Front one on my motor had to be swapped as it had been mauled & burred by the gorilla that did the last rebuild so professionally . 90ft/lb by the way is what my stock bolts are at right now, if you have ARP 100ft/lb would be my choice for peace of mind (and obviously a retorque after 150/200miles max.).
Best of luck for take two, for once I'm gonna hope it's NOT 3rd time lucky!!!
EDIT-: Oh cre, on the subject of hollow studs surely one could have ARP's or even stock bolts drilled part way up to create the same effect (I'm thinking simply as a place for any remaining shit to go, instead of it hydraulicking up under the base of the stud/bolt hence making it feel tighter than it is) provided it was done accurately & not on a hand drill & vice of course!
