Old 04-17-2010, 11:00 PM   #1
89supra884
89supra884 is on a distinguished road
Default headlights wont turn off after swap
well i just did my gte 5 speed swap, into my 89, and now for some reason my head lights will not go off, even when they go down. the runners and inside light will go off, just not the lights. i am also getting not tach reading. i belive i used a pre 89 engine wiring harness, but i did not touch the engine harness. i have no clue what is goin on.
anyone?
thank you
89supra884 is offline   Reply With Quote
Old 04-17-2010, 11:19 PM   #2
spoolmk3
spoolmk3's Avatar
spoolmk3 is on a distinguished road
Default swap
not sure what you did with the lights, but your tac. will not work. you will have to replace the cluster or run an aftermarket one, you can get the signal from the little plug on the side of the diagnostic box
motor swaps are a sad result of a non tuner!
If its a 7m / leave it a 7m
spoolmk3 is offline   Reply With Quote
Old 04-18-2010, 04:51 AM   #3
89supra884
see thats the thing, all i did was wap engine harness, i didnt touch the lights, its really weired,
Old 04-18-2010, 02:54 PM   #4
89supra884
and i do have all of the gauges for the turbo engine, just no the cluster that holds them, if i install them will i get a tach reading
Old 04-18-2010, 06:16 PM   #5
spoolmk3
spoolmk3's Avatar
the difference is in the dash harness, you need to trace the black wire from the coil packs to where it meets the dash harness and see what color the wire switches to and run that wire to the tach
Old 04-18-2010, 09:30 PM   #6
89supra884
cool, thankyou, and any advice about the headlights?
Headlights won't turn off. - was: Need some help plz!!! kusupra3 Non-Generation Specific Questions 15 02-08-2010 12:52 AM
Headlights going bonkers! RNEMESiS42 MKIII Supra 3 12-17-2007 08:39 PM
89 Supra Turbo w/1JZ Swap Problems Donnies Foreign Car Non-Generation Specific Questions 1 02-02-2006 05:03 PM
