Old 04-23-2010, 08:57 PM   #1
89supra884
89supra884 is on a distinguished road
Default swapping clusters make my tach work again
well upon doing my friends headgasket, i saw it was for a turbo 5 speed, and his car is auto na, and i had just swapped a turbo 5 speed into my car, and the current cluster is for a non turbo auto. i was wondering if i swapped them over if the tach would work again or is there anyting else involved other then just swapping them.
thankyou
billy
89supra884 is offline   Reply With Quote
Old 04-24-2010, 01:28 AM   #2
The only difference in the tachs are three or four resistors... I've posted a picture showing the specific differences here before. The tachs are not interchangeable, but by swapping the resistors or just swapping the tach you'll be fine.
Buying Supra ? What To Know First mrnickleye Supra FAQ 18 12-28-2011 03:25 AM
can you make these work with a 1jz swap..? JZA70dood Non-Generation Specific Questions 0 08-12-2009 04:17 PM
how do i make the hatchback keyless entry work? ogkush Non-Generation Specific Questions 6 02-21-2006 11:18 PM
