#1 |
alright i recently got a 1986.5 supra na 5 speed and im finding it a bit confusing alright here it goes
problem 1 i have no spark i would like to test my igniter which im pretty sure is the problem but my haynes manual says that the igniter/coil setup i have is actually for a 1983 to 1985 model and that there is no way to test the coil from a 86 and the coil it shows is WAY different than what i have problem 2 check engine light? is there actually a light because i know in the cars we work on (usually 1990 or newer) if you dont see a check engine light when the ign is on car is off it means the ecm is not registering but ive been staring at my dash for 30 minutes and dont see any engine light just coolant battery oil if you could show me a pic it would be much appreciated thank you for any help im sure my problems just arent addressed in my manual as its a half year model and that tends to happen |
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
The 7M-GE uses an individual coil unlike the 7M-GTE, the diagnosis is similar to the '86 MKII, IIRC.
Yes, of course there is a heck engine light. It's located with a couple other by the "door ajar" indicator toward the center of the cluster. It is used for checking for diagnostic codes and you're right, it should be on when the key is ON but the car OFF. It is NOT on while the car is running while diag codes are present, except for under a few circumstances, you need to check them manually when you are having trouble whether you've seen the light come on briefly or not. See the MKIII FAQ for a thread with the details.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
thanks got it all figured out and running great my engine fuse was in and good but the wires at the terminal were loose and the check engine light has been rubbed to black on my car instead of the stock white so i didnt see it thanks though
#4 |
Wow... I just read your other thread... 900RWHP huh? A LOT less bravado would be well advised if you need to ask questions like this.
problems problems problems.... | 86SupraMan | MKIII Supra | 5 | 02-04-2008 04:28 PM |
Starting problems and accleration problems! | alekjame22 | MKIII Supra | 6 | 03-17-2007 11:19 PM |
Oil leak problems | adellicson | MKIII Supra | 1 | 03-04-2007 10:11 PM |
random dying problems (1989 n/a) | thechori | MKIII Supra | 11 | 11-06-2006 05:03 AM |
problems, problems, and problems | tone loc | MKIII Supra | 6 | 09-06-2006 04:35 AM |
