Old 08-31-2005, 12:27 AM   #11
Turbo Targa
Turbo Targa is on a distinguished road
How much does the Lexus swap usually cost? Where can I find the parts? It sounds like it would be a better upgrade then the fuel cut defender.
Turbo Targa is offline   Reply With Quote
Old 08-31-2005, 01:59 AM   #12
ddmcse
ddmcse's Avatar
try an online auto junk yard for the lexus afm i got mine that way but it was years ago for about 75$
the 550 injectors are everywhere
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-31-2005, 04:41 AM   #13
Poodles
Poodles is on a distinguished road
Also, it's a good upgrade int he end, as it sets you up for even more power. Once you go that high, you still will have to get a FCD, but the fuel cut is a good thing in the end, as it stops overboost if you do something wrong...
Poodles is offline   Reply With Quote
Old 08-31-2005, 07:08 PM   #14
SupraDietrich
SupraDietrich's Avatar
SupraDietrich is on a distinguished road
So what you guys are saying is the best idea would be to get the lexus air flow meter swap with the 550 injectors and then put in a FCD anyways just to be safe... sounds pricey, but worth it i'll bet, but yeah my friends supra has stopped doing that as much now, as long as he lets the turbo warm up first... anyways, thanx again... :lol:
I want a supra SO SO Badly...
SupraDietrich is offline   Reply With Quote
Old 09-02-2005, 05:42 AM   #15
Poodles
well, he'll need a FCD to go above...I think it's like 20 psi....can't find the info ATM...too late...
Old 09-02-2005, 10:24 AM   #16
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
just a reminder to those putting in fcd's
make sure you have the fuel to support the extra boost if you turn it up!!!!
or.... rebuild time!
Pics of my build.
Do a diagnostic first!
Old 09-03-2005, 07:59 AM   #17
WoFo Speed
WoFo Speed is on a distinguished road
what is the fuel cut set at? i just got a 87 Turbo Supra and went for a test drive and it pulled alot harder than my friends 90 Trubo Supra. Come to find out the wastegate line was un-hooked. so i put it back on and it topped out at around 8psi
WoFo Speed is offline   Reply With Quote
fuel cut defender turbo xs joel williams MKIII Supra 8 08-21-2005 09:22 PM
