Old 04-22-2010, 06:11 PM   #1
StonecoreTx
StonecoreTx is on a distinguished road
Exclamation wheel fitment question
fitment question. I've decited to go for a oem/mesh look. i'm thinking some GTA mesh wheels off of a 80's trans am. would it be possible? similar to crown vic meshes. I really want this wheel or some like it. any tips will be appreciated asap because I found a set for dirt cheap and would make my day if they fit.
http://www.tacreationsusa.com/firebi....htm#GTAWheels - this site has alot of into about the GTA wheel.
GTA wheel specs:
Size : 16" x 8"
Backspacing Front : 4.75"
Backspacing Rear : 5.25"
Bolt pattern : 4.75"
Material : Aluminum
Finish : Painted Centers/Cleared Lips
will these fit?
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
Old 04-23-2010, 01:45 AM   #2
There's a thread in the FAQ about fitment, please check there first:
http://www.toyota-supra.info/forums/...t-q-and-a.html
If it doesn't have the answer please add it once you find it. From my experience you might have a hard time when referring to back spacing versus using offset with most Toyota and other import guys.
Old 04-23-2010, 05:32 AM   #3
StonecoreTx
I tried to post my question in that section twice but it didn't seem to go through..? feel free to move it ofcourse, I just really want to know if these GTA wheels would fit by bolt pattern, I plan to get a set soon.
Old 04-23-2010, 12:44 PM   #4
The FAQ sections are moderated and posts require admin/mod approval. Think of it as more of a catalog of answers to common questions.
You just need to google the bolt pattern, center bore and offset of those wheels to find out if they'll fit. The info on ours is in the FAQ.
Tire and Wheel fitment Q&A 1988gte MKIII FAQ 124 03-16-2013 02:53 AM
Wheel bearing question suprabahamut MKIII Supra 4 03-12-2009 01:17 AM
Supra space saver wheel question aquanuke Non-Generation Specific Questions 0 03-25-2008 10:24 PM
Question concerning disasembling steering wheel Chambers MKIII Supra 2 10-14-2007 03:40 PM
Steering wheel question! lifesnotfair Non-Generation Specific Questions 0 01-14-2006 02:32 AM
