Old 04-23-2010, 10:39 PM   #1
GettaRobo
GettaRobo is on a distinguished road
Default Fuel cut RPM
Hi, my car is an 88 NA and in the haynes manual, it says the fuel cut rpm should be 1800 for cut off and 1200 for the return. On my car, I'm getting a 1950 cut and a 1450 return. What the heck does this mean? Neither the haynes nor the TSRM really explain anything about it other than how to check it.
GettaRobo is offline   Reply With Quote
Old 04-24-2010, 01:26 AM   #2
If you're going by the stock tach then definitely don't worry about the variation. Honestly, that deviation isn't so bad and may be due to aging electrolytic caps in the ECU.
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
