Old 08-16-2022, 09:22 PM   #11
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Describe your particular symptoms. Does it crank but not start? Does it not crank when it's hot unless you cycle the switch many times? If that's the case then check the EFI relay behind the battery. These can go bad from heat soak and give an intermittent failing. Here is a link to the online wire diagram on the starter circuit page. http://cygnusx1.net/Supra/Library/TS....aspx?S=D&P=32
Wrist pin issue -- Was: Ris pen issue KeelanWiese MKIII Supra 3 02-13-2010 07:38 PM
Sputtering Issue gorillaguy8 MKIII Supra 5 02-02-2010 09:52 PM
Overheating issue, searches suggest BHG but i'm not convinced!!! poboy69 MKIII Supra 8 05-01-2009 05:38 PM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
Intermittent Electrical Problems on a ’93 MKIV gjs_cds Shops & Part Reviews 0 05-22-2006 02:39 PM
