Old 04-27-2010, 06:46 PM   #1
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
Default Do I even have a MAP sensor??????????????????
Ok so looking over my car the other day and I think I may not have a MAP sensor.
Looking on ebay and stuff it looks like MAP sensors say SENSOR ASSY. TURBO PRESSURE.
I may be wrong but what looks like my "MAP Sensor" located on the back of the intake manifold near the firewall (its just zip tied on there) says: SENSOR ASSY. VACUUM
It has three wires coming out if it, one is green with a black stripe, one is blue with a black stripe and one is brown. The vacuum hose connects to the intake manifold.
Any help or ideas? This may be why I am not boosting properly?
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
AlexSchuSupra is offline   Reply With Quote
Old 04-27-2010, 07:16 PM   #2
the only manifold pressure sensor on the 7M is only used for the boost gauge... unless you're using hardware to run one in place of the AFM.
Old 04-27-2010, 07:45 PM   #3
AlexSchuSupra
I'm sorry I should have explained further. This is a 1JZ-GTE swap in my MK3
Old 04-28-2010, 12:38 AM   #4
Oh, ok... yes, you do have one and I believe it is labeled as a "vacuum" sensor (that's how it is in all the Toyota's I've worked on with one... which isn't too many, though).
Old 04-28-2010, 05:58 PM   #5
AlexSchuSupra
Ok just checking. All the ones from other 1jz's I have seen say turbo boost pressure so I was starting to worry. Thanks
Old 04-29-2010, 12:06 AM   #6
If you're worried that you're is not the right one then go by the part number. The name on the tag may have been changed. Additionally, the part may have been superseded any number of times so don't be surprised if you find multiple part numbers for that application.
Old 05-02-2010, 01:21 AM   #7
AlexSchuSupra
Ok yes alot of part numbers changed. I just looked on Ebay again and a MAP sensor for a 2jz-GE says Sensor ASSY. Vacuum. Now I am starting to think this is a non turbo map sensor!
Old 05-02-2010, 04:16 PM   #8
eBay as a parts reference system??? Bad idea. lol. You should head over to SupraMania and ask in the 1JZ/2JZ section WITH THE PART NUMBER if it's the correct part. Jeff Lange over there may be willing to look it up in Toyota's system for you too, if you ask nice.
I do hope that's not just sitting in your engine bay.
Old 06-24-2010, 01:32 AM   #9
AlexSchuSupra
Well Ebay worked.... It was a non turbo map sensor. Got one for 100 bucks and viola!
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
A340E Speed Sensor GettaRobo MKIII Supra 0 08-06-2009 06:59 PM
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
550 injector & lexus air flow troubles o2 sensor? night-rider MKIII Supra 1 09-03-2007 08:52 AM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
