Old 06-20-2010, 04:04 AM   #1
907mge
907mge's Avatar
Default Why Not A 300hp NA Stock?
As I was pondering the complex workings of my 2zzge I was thinking a straight 6 is no more than a four cylinder with 2 more cylinders. So if the 2zz is 1.8L and produces 180hp factory why could a 300hp 3L not be made. Of coarse that will never happen but think of the sound of a factory na running at 8k rpm.
This maybe in the wrong section so i'm sure it might get moved.
Old 06-20-2010, 05:54 AM   #2
They have been... Toyota just got out of the game (after doing a LOT of the homework for the other guys). As to why everyone's left the I6 behind; Part of the problem is the size... a V8 with similar chamber sizes requires less length and nowadays produces enough power to satisfy most consumers... so the I6 gets kicked to the curb.
Old 06-20-2010, 01:46 PM   #3
wstanek
wstanek's Avatar
wstanek is on a distinguished road
I 6 ftw =D
wstanek is offline   Reply With Quote
Old 06-20-2010, 09:31 PM   #4
907mge
907mge's Avatar
Is a I6 better than a v6 of the same displacement? Besides that a I6 seems to be simplier. I know alot of big diesels use the I6 comfiguration.
Old 06-20-2010, 11:44 PM   #5
btwilson86
Super Moderator
btwilson86's Avatar
I believe that I6 engines tend to have more torque compared to similar V6 engines
Old 07-04-2010, 04:41 PM   #6
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
If you were to run a 7m to 8k you better pack your pistons with parachutes so you can catch them on the way back down. The problem with that in relation to a 7m is piston velocity and with it tensile load on the connecting rod. Piston velocity is already very high in the 7m to the the various revisions in the M block being bored ( thus adding a heavier projectile) and stroked (incresing piston velocity) so many times that it is very near it's physical limits. Keep in mind that connecting rod tensile loads increase with the differance in rpm squared, meaning that the difference between 6000-7200 would yield a 144% increase in tensile load. so going up from 6400 to 8000 is a 256% increase in tensile load to the connecting rod. That is why it wouldn't work specifically with the 7m, However, on a more modern engine it would be possible. Though I think a lighter forged piston and a larger bore but shorter stroke would be the way to go
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
Old 07-04-2010, 09:15 PM   #7
907mge
907mge's Avatar
I was not talking about a 7m, since they are not a vvtli engine. My 2zz runs at around 8k rpm stock safely. I was just saying about how a I6 is like a 4cyl with 2 more pistons.
Old 07-04-2010, 09:31 PM   #8
wstanek
wstanek's Avatar
and you know why the big diesels use that configuration? because it fucking rocks!!!!
1987 N/A 7MGE manual transmission slight rod knock never driven it yet... legally~
Old 07-05-2010, 02:29 AM   #9
Supra_Freak_7m
It's cool, I wasn't bashing ya, just throwing a little science in there for you. Personally I'd like to have a 4age that would rev to 13k but the motor would only last 40k miles at best, but it would be fun....
Old 07-05-2010, 03:14 PM   #10
wstanek
wstanek's Avatar
yeah that would be cool a inline 4 revvintg to 13k haha u would be screaming down the street literally! =D
How much HP can a stock 1JZ engine handle? Sperstad MKIII Supra 1 07-06-2010 06:58 AM
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
