Old 05-04-2010, 01:50 AM   #1
Life is Supra
Life is Supra is on a distinguished road
Default Turbo ct26 problem
I have a problem with the impeler wheel on the sides three has missing pieces on the edge and I found oil in pipe in betwen intercoler all the way to turbo inlet-please help????
Life is Supra is offline   Reply With Quote
Old 05-04-2010, 02:07 AM   #2
I'd be more worried about where the chunks of metal ended up, myself. There's no question about how to proceed here... turbo must be rebuilt or replaced; intake piping, manifold and throttle body all need to be THOROUGHLY cleaned out; the intercooler needs to be professionally flushed; you need to do a compressions test to make sure none of the debris entered the engine and chewed up the cylinder walls... a leak-down test would be even better.
Old 05-06-2010, 12:31 AM   #3
Life is Supra
Thanks for your knowledge...by the way that happens recently when one day when I driven her the turbo pressure drops a little bit then normal-4.5PSI...stock boost is 5.5-7.5PSI,and when I took the air hose down I saw that the impeler wheel is like that.Tell me if I can drive it now or not because its a daily driver?
Old 05-11-2010, 11:47 AM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
phwoarrr, I wouldn't drive it like that. If your thinking of doing so just imagine for a moment that one of those hard sharp chunks of turbo jams down the side of a piston. That shard of metal then scrapes up & down the cylinder wall over 700 times a minute at tickover, rev the engine it'll be making the journey anywhere up to 5500 times a minute. Now think how many strokes of a file it takes to make a nice mess of a chunk of steel...
Your choice ultimately but I wouldn't wanna risk it...
1990 supra turbo problem. Rob1 MKIII Supra 5 04-12-2010 01:34 PM
