#2 |
There are a few options but rebuilding your 7mgte is probably the easiest and least expensive if you do it yourself. Yes the 1jz and 2jz will work. The 1jz is said to be much easier and less expensive than the 2jz though. The main thing is that if you reabuild you current motor you will know what is in it and the 7mgte is still a very good motor. If you seach you can find all the the info you need.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine Help! | born2drv | MKIII Supra | 9 | 02-01-2011 08:14 PM |
| rebuilt hard to crank (high engine resistance); need advice | cbrewster | MKIII Supra | 4 | 09-28-2009 04:52 PM |
| problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
| Keeping Engine Cool | mrnickleye | Supra FAQ | 0 | 06-04-2005 10:02 PM |
