Old 05-11-2010, 01:07 AM   #11
bryanf89
My aftermarket radio doesnt have any security on it, only the option of removing the actual radio. The alarm does have a vibration sensor that activates the alarm when enough force is applied to the car.
Old 04-15-2011, 10:43 PM   #12
interested!
Default battery draining?
Hi! My battery drained -dead-- so I bought a new one only to find that I had accidently left the boot light switched to stay on -check this by operating the boot lid closed switch while the boot is open -if the light stays on thats the problem solved!
Old 04-16-2011, 08:21 AM   #13
87hilux7mge
87hilux7mge's Avatar
if you didnt have your sterio and alarm installed professionally, check your wiring over. if you did, the alarm is most likely the problem for the afor-mentioned problems. alarm systems are tricky, especially if they are straight wired to power and not set as an on demand or with a back up system.
when i had an alarm in my camaro, it had its own proprietary power system (just a small 12v system) that was charged off of the alternator and disconnected from the main power system.
go invest in a volt meter, its well worth the price of 20-30 bux for a craftsman one, im glad i have mine.
PLEASE HELP ME!! Supra battery :( SquamishSupra MKIII Supra 6 10-18-2009 03:39 PM
Battery Upkeep mrnickleye Supra FAQ 0 02-21-2007 03:30 AM
wiring short drains battery misupra MKIII Supra 13 09-15-2006 04:55 AM
new battery no start mosupra87 MKIII Supra 1 03-23-2006 08:16 PM
batteries draining. miisterMK3 MKIII Supra 4 11-02-2005 12:21 PM
