Old 08-28-2005, 09:27 PM   #1
92supra
92supra's Avatar
92supra is on a distinguished road
What do these switches really do, i found a website that explained it a while back but forgoten it , Some say that the ECT works like the Honda V-tec, and produces alot more power by increasing everything really quickly, is this correct? some say its for heavy weights attached to the car for the automatic gearbox to cope. please explain. many thank you's. sorry if it sounds stupid just confused lol
VIST MY WEBSITE PLEASE
92supra is offline   Reply With Quote
Old 08-28-2005, 09:39 PM   #2
92supra
92supra's Avatar
overdrive that allows you to travel at high speeds at lower rpms...thus saving gas etc. if you were going 130 mph in 5th ud maybe go like 6k rpm...but in overdrive u could do it in 4k rpms. well i jus made those numbers up but a z06 vette can do 171 mph at 4250 rpms in overdrive. but in a normal gear itd be redlining
"evolutionm.net "
best start using that with petrol prices B)
going to look about ECT now, anyone?
Old 08-28-2005, 09:55 PM   #3
92supra
92supra's Avatar
"DaMoNe6969" @ http://www.automotivehelper.com
the ECT is the electronic control transmission.. I dont know about manually shifting the tranny without hurting it.. that one would be news to me??
The ECU has various shift patterns programmed into it.. When your ECT is on or "power" The ECT ECU will change the shift patterns and lock-up accordingly..
Your upshifts will come later and harder, at a higher speed.. depending on your throttle position..
Makes a Huge difference in my car
wait is over, probley best to leave this information here for future use
Old 08-29-2005, 06:44 AM   #4
Poodles
Poodles is on a distinguished road
alright.... To truely control your auto tranny, you'll end up using these buttons a lot to shift it better.
4 speed tranny, overdrive is 4th gear, if you turn it off, it will ride in 3rd. ECT is a bit more involved than that though, if you're on economy, you'll only downshift one gear when you floor it, with it in power mode, you'll downshift two gears, and also hold the gears a lot better, it's like having a shift kit
You can also control it manually, but that is generally not accepted as a good idea as it increases pressure and heat in the tranny...
Poodles is offline   Reply With Quote
Old 08-30-2005, 05:01 AM   #5
mrnickleye
mrnickleye's Avatar
When in 'sport' mode, it raises the shift point 800rpm's for the same throttle plate position (where your foot is on the pedal).
e.i.: if your trans upshifts in 'normal' mode at 2K rpm, in 'sport' mode it will shift at 28k rpm. It puts you more into the power band of the engine, thus 'feeling' like you have more HP's.
Sport mode is all I drive in, because this 'fat pig' needs to keep up with those 'mothers' in the SUV's and minivans. :angry:
Old 08-30-2005, 05:04 PM   #6
92supra
92supra's Avatar
thanks for the feedback, gave it a good shot of ECT today, launches loads better with it on. Im currently in a situiation where i feel like selling it and buying something smaller and part of me wants to keep it and start modifying it.
Buttons igosaur MKIII Supra 5 07-07-2008 03:58 AM
Top Speed SupraSaver87 Non-Generation Specific Questions 10 08-19-2006 03:10 AM
automatic overdrive petewren MKIII Supra 3 05-18-2005 02:16 PM
