Old 05-06-2010, 02:48 PM   #1
wstanek
wstanek's Avatar
wstanek is on a distinguished road
Default 87 supra brake lines
hey im new to this fourm just bought an 87 supra in emaculate condition 2 days ago exccept for the brake lines. if anny1 has anny tips about hidden problems while replacing them please let me know thanks.
wstanek is offline   Reply With Quote
Old 05-06-2010, 10:33 PM   #2
mirage83
If you're replacing the lines make sure you've got the proper size wrenches and that you try and turn the fittings the proper direction. Things can get ugly if you round-off the fittings.
After you've replaced all the lines bleed the entire system well. I mean keep bleeding (in the proper sequence) until you have clean fluid coming out the bleed valve at each wheel cylinder. At first you're almost certain to have coffee-looking crap coming out, but by effectively replacing all the fluid in your system you'll end up with better feeling and working brakes.
Old 05-06-2010, 11:09 PM   #3
907mge
907mge's Avatar
I would recommend the Goodridge Braided Steel lines. I've used them and have had no problems with them. They run about $140.
Old 05-06-2010, 11:46 PM   #4
mirage83
That's what I'm running on mine. Easy to switch out, good quality lines. Just got to make sure you route them properly or you'll end up rubbing holes in them on the shocks & coils.
Old 05-10-2010, 12:43 AM   #5
wstanek
wstanek's Avatar
thanks for replying i know how to bleed but yeah definitly if you round of the corner's ur screwed
Old 05-10-2010, 01:37 AM   #6
wstanek
wstanek's Avatar
where u buy these im in canada so haha w.e
if u can buy on ebay try to give me name and product number
Old 05-15-2010, 01:43 PM   #7
wstanek
wstanek's Avatar
Post
what size are the supras brake lines on an 87 non turbo non targa
87 supra brake booster problem Rob1 MKIII Supra 2 11-16-2009 04:23 PM
Supra TT Brake Calipers on my MKIII tonystarks Non-Generation Specific Questions 5 05-04-2006 10:20 PM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
