Old 05-06-2010, 06:08 PM   #1
jcastro
Default ????? need held realy appreciate it
I had a air leak in my turbo supra that i fixed the other day it was just a small hose under the intake manifold. after the fix i thought i was gana b able to spool back up to 8 but when i went for drive i spooled up to 7 then i released the gas and my blow off valve went off but this time sounded really strange then the car just died on me. I have a stock supra with a greddy type rs blow off valve I did this late so did have time to test stuff will do today tho if any one can shine light on this it would really help thanks for every thing in the past guys. u guys r of a lot of help
thanks
jcastro is offline   Reply With Quote
Old 05-06-2010, 07:34 PM   #2
supraflymkiii
supraflymkiii's Avatar
supraflymkiii is on a distinguished road
Its possible that it died because you don't have you're bov recirculated. My 87 use to die same as you're explaining yours when I had a Greddy Type RS BOV which wasn't recirculated.
supraflymkiii is offline   Reply With Quote
Old 05-06-2010, 08:09 PM   #3
jdmsoup
jdmsoup's Avatar
jdmsoup is on a distinguished road
sounds legit. my supra does the same thing sometimes because my bov is letting off into the atmosphere.
87 Supra Turbo.
JDM 7M-GTE.
CT-26 set @ 10-12 pounds.
xs sport manual boost control.
hks ssq bov.
greddy front mount.
3"downpipe with 3" straight through piping back to tip
kyb shocks.
"In life its not what you know, its who you know"
jdmsoup is offline   Reply With Quote
Old 05-06-2010, 10:14 PM   #4
jcastro
so its my bov
Old 05-06-2010, 10:16 PM   #5
jcastro
ima try the stock one out see if it still dose it thanks ill let u guys know what happens and what bov are u guys running now
Old 05-07-2010, 04:26 AM   #6
jcastro
It was the dam bov i adjusted it and its all good im still not spooling up to 8psi tho like i use to found out it could be the turbo so checked it out i got a lil bit of oil in the intercooler piping near the intercooler do u guys think its time for a new turbo or is that normal.
Old 05-07-2010, 04:33 AM   #7
supraflymkiii
How does your exhaust look is it blue? The oil in your pipes could be PCV oil to check that pull your accordion hose off and see if you have a bunch of oil in the accordion hose. If that checks out ok then your turbo seals are probably going and in that case it would be a wise decision to replace it asap so it doesn't leave you stranded somewhere and not to mention it won't be fun to clean out all your i.c. piping and intercooler.
Old 05-07-2010, 07:56 PM   #8
jcastro
thanks man did wut u said its time for a new turbo
