Old 05-09-2010, 11:25 PM   #1
Peter M
Peter M is on a distinguished road
Default struts questions
so i was looking at new JDM rear and front struts on ebay, after my brother got new ones for his 2000 integra.
and everything looks pretty simple to put on my 89 supra (non-turbo)
but there is like these gaskets, on each side of the engine and in the hatch. ive seen some engines without them completely. but theres alot with them.
so my question is do i try and completely take them off and put on the strut, or order the struts and see if they go on top
and by the way, im 15 and have been working on this car non-stop for the past year, so i like doing work, but i dont exactly know what im doing.
so im just checking in on this.
thanks guys!
Peter.
Peter M is offline   Reply With Quote
Old 05-09-2010, 11:39 PM   #2
907mge
907mge's Avatar
Those "gaskets" are called strut mounts and I don't know why you call the struts JDM. I'm sure the USA model uses the same suspension as a Jdm one. Be careful when messing with struts since the springs can be under tension. And no it is not that easy to do struts on the mk3 with the double wishbone suspension. It took me about a day and a half but i also did the sway bars. Good Luck.
Old 05-10-2010, 12:01 AM   #3
Peter M
well all i thought, and all it looks like, is you take off the strut mounts, then put in your new strut and bolt it back together.
would it help if i put like the whole back end up on some jacks? to releive some tension.
Old 05-10-2010, 12:11 AM   #4
907mge
907mge's Avatar
Yeah I don't think you understand. Take a look though here.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Old 05-10-2010, 12:34 AM   #5
Peter M
okay so if i did manage to do this... which i understand now about those struts. that it would replace those strut mounts?
so i wouldnt even need those rear strut mounts?
Old 05-10-2010, 12:46 AM   #6
907mge
907mge's Avatar
You should get all the parts to do it right. But you might not have to replace the strut mounts but should get the rubber insulators.
couple of questions about my 7MGE motor SDK MKIII Supra 2 12-13-2009 07:26 AM
Purchasing and upgrade questions for a 1993-1996 supra non turbo slayer8925 MKIV Supra 9 04-29-2009 09:31 PM
Removing the struts supraman121 MKIII Supra 7 10-15-2007 02:53 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
help picking out new struts mad_dicer MKIII Supra 19 10-11-2006 01:09 AM
