i wanted to know if my engine idles too low, it idles at about 500-600 when warm. Also, when i pushed the car hard to the point where turbo kicks in, the engine sometimes dies out when i put it in neutral or let off the gas. Can this be due to the low idle?
not enough fuel pressure lean!!
clogged or dirty fuel system?
Check for vacuum leaks
1987 Supra Turbo Targa Blue 5spd 175K, 3" Exhaust from Turbo back, Lowered 1.5", 89 Steering Wheel and Climate Control, JDM Power Folding Mirrors, HKS Fan Controller, Greddy Turbo Timer, HKS EVCIII Boost Controller, Boost Gauge, Deleted Boost Gauge in Cluster for Volt, MKIV Non-Turbo wheels 1987 Supra N/A Coupe Blue Auto - Parts Car 1987 Supra Turbo Coupe Black 5spd - Bought with a spun bearing - RIP 1987 VW Jetta GTI Auto 89k |
i just finished changing most of my vacuum lines with silicone, but is that a typical idle range?
#6 |
yes that is normal idle. it says what your idle should be under your hood on that sticker that says 7m-gte
idle problems | 88 supra turbo | MKIII Supra | 14 | 03-13-2010 03:43 AM |
Car wont idle (wont stay on) | Kevin | MKIII Supra | 29 | 09-02-2009 02:07 PM |
won't idle | 3.0trd | MKIII Supra | 6 | 06-15-2009 07:23 PM |
Idle problem 1988 Supra non turbo | jimwww | Non-Generation Specific Questions | 3 | 01-24-2006 03:50 PM |
HELP!!!! '87 Supra idle problem | Morpho | MKIII Supra | 0 | 10-03-2005 02:40 PM |
