#1 |
Has any one done this and if they haven't is it possible idk this came out of no where
#2 |
Super Moderator
I haven't heard of a M engine with a 6 speed, from what I can find out the V160 6 speed manual does not have a removable bellhousing, so that would not be a suitable transmission.
On a side note, while looking at Toyota tranny's I discovered that Toyota made an 8 speed automatic transmission, the AA80-E. I can't even fathom so many gears, two of which are overdrive gears
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#3 |
dam 8 gears well it was worth a try i live close to the boarder and iv heard of ppl fixin their bell housing by welding i know that a lil on the cheep side but mabe its possible to fabricate a way to make it fit
#4 |
Super Moderator
Well, I suppose with some good fabrication skills it could be possible. I personally don't think the extra gear would be worth the headaches...
Although it would be cool to drive a 6 spd 7M
#5 |
true and i finally have my supra running reliably (hopefully I didn't jinx it)
#6 |
There are people that have put the getrag 6 speeds on there 7ms I think you can get a bellhousing adapter then you just have to pound out your tranny tunnel a little and i don't think the shifter mount lines up with the stock hole. Check out Supramania.com or supraforums.com they probably have more info on it.
Thread Tools | |
Display Modes | |
5 speed to a 6 speed | supraman623 | MKIV Supra | 14 | 06-30-2013 11:59 PM |
Blitz MSTT Speed adjustment | SunDan | MKIII Supra | 5 | 11-17-2009 07:41 AM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
A340E Speed Sensor | GettaRobo | MKIII Supra | 0 | 08-06-2009 06:59 PM |
speed o-meter or speed-cable help... | hangsupra | MKIII Supra | 0 | 10-15-2006 08:54 PM |
