#1 |
If it had 12 before you don't want to just throw 134a in it. The two aren't compatible, oils or refrigerant. He'll want to replace the dryer, expansion valve, and a few of the seals (at a minimum) if he wants to convert it over.
#2 |
A few sources for your reading pleasure:
http://www.thirdgen.org/retrofitac http://www.machinerylubrication.com/...vert-to-r-134a |
#3 |
And you do convert, you may well want to consider a new parallel-flow condensor as the OEM condensor won't work the best in the world with 134a.
Cold Start System Testing (hard starting) | mrnickleye | MKIII Supra | 12 | 11-13-2010 08:32 PM |
Supra idea, simple, cheap cold air intake | 82Supra | MKII Supra | 1 | 09-02-2009 02:43 AM |
SUPRA LSDs AND COLD AIR INTAKEs QUESTION | C0o0n | Non-Generation Specific Questions | 2 | 08-10-2008 02:33 AM |
Running very rich | OmeGa | MKIII Supra | 3 | 12-09-2006 09:59 PM |
supra running rough | finn | MKIII Supra | 0 | 09-25-2006 07:10 PM |
