Old 05-10-2010, 10:21 PM   #1
ynnek
ynnek is on a distinguished road
Default AC Not blowing cold / AC fan not running
1988
Non Turbo
Automatic Trans
When I turn on the AC inside the car it is not blowing even cool. I dont think the clutch is kicking in. If may have a refridgerant leak. But also at running temp if I turn the AC on the condensor fan does not come on.
With the car not runningThis all worked last summer. Any suggestions would be greatly appriciated
ynnek is offline   Reply With Quote
Old 05-17-2010, 01:40 AM   #2
ynnek
Default Still cant figure it out
Gonna take it to the local Toyota dealership this week.
Old 05-17-2010, 01:49 AM   #3
907mge
907mge's Avatar
If there is no refregerant in the system the compressor won’t run. So I would try refilling it with new 134a since the r12 has probably leaked out. All of the r12 probably leaked out over the winter time.
Old 05-17-2010, 10:14 PM   #4
mirage83
If it had 12 before you don't want to just throw 134a in it. The two aren't compatible, oils or refrigerant. He'll want to replace the dryer, expansion valve, and a few of the seals (at a minimum) if he wants to convert it over.
Old 05-17-2010, 10:44 PM   #5
907mge
907mge's Avatar
A few sources for your reading pleasure:
http://www.thirdgen.org/retrofitac
http://www.machinerylubrication.com/...vert-to-r-134a
Old 05-18-2010, 10:40 PM   #6
mirage83
And you do convert, you may well want to consider a new parallel-flow condensor as the OEM condensor won't work the best in the world with 134a.
Supra idea, simple, cheap cold air intake 82Supra MKII Supra 1 09-02-2009 02:43 AM
SUPRA LSDs AND COLD AIR INTAKEs QUESTION C0o0n Non-Generation Specific Questions 2 08-10-2008 02:33 AM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
