#7 |
Since you'll have the engine out of the car you might as well order a gasket and seal kit and replace all seals and gaskets. Check the turbo for shaft play if it has a little its fine but if it has so much that the compressor wheel rubs the housing then its time for a new one, also make sure the inside of the turbo isn't covered in mass amounts of oil. I don't see many other things on these things going bad except for internal parts but I don't thkink yhou'll want to rip into the whole engine.
1988 Toyota Supra Turbo runs very rich need help | PhillyKorean | Non-Generation Specific Questions | 0 | 10-25-2008 03:28 PM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
HorsepowerFreaks Turbo M3 vs Single Turbo Supra | ChrisB | Non-Generation Specific Questions | 0 | 01-01-2007 04:56 PM |
