hey my car just got back from shop because headgasket job. before the boost gauge would rise, but now it doesnt. were is the connections to see if they misplaced them??. when driving doesnt feel as quick. gears dont pull as much. takes forever to get to 60. suggestions?? and yes im getting aftermarket boost gauge
Sounds more to me like an intake coupler is off, loose or has a big tear in it.
The boost gauge's sensor is by the cruise control actuator behind the front driver's side wheel well... it is not used by the ECU though so while the gauge won't read anything it wouldn't affect performance at all. EDIT: And check for error codes, the details are in the MKIII FAQ.
ok so now its boosting correctly according to aftermarket gauge. still feels kinda wierd, whats stock boost 5-psi??
Bone Stock w Upgrades ;-)
I believe its computer limited at 7.3 PSI
No, the ECU has no idea what boost level you're running. The only control is the wastegate actuator (and boost leaks). The acceptable boost range is something around 9 to 6psi (I can't remember right now, it's in the TSRM though if you wish to look it up)... it's not uncommon for the wastegate actuator's spring to weaken over time causing a drop in boost pressure.
#6 |
I have added 3.5mm of washers under the waste gate bracket to shim it up.
#7 | |
![]() Quote:
Here: http://www.gusmahon.org/html/boostcontrol.htm
Audio and a lot of other things wrong with car | bluemeate | MKIII Supra | 4 | 05-18-2010 07:07 PM |
Boosting my 88 7mge | lemonhead4696 | Non-Generation Specific Questions | 5 | 07-02-2008 02:24 AM |
carfax report. (sorry earlier posted to wrong category) | supramkiiiboost | Non-Generation Specific Questions | 0 | 09-21-2007 10:45 PM |
My fenders look wrong | Kristian_Wraae | Non-Generation Specific Questions | 14 | 05-07-2007 03:20 PM |
Stock Block | Evilfurby | MKIV Supra | 56 | 01-09-2006 02:23 AM |
