Old 05-14-2010, 02:46 AM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default wiring/lighting help!
I have been having some problems with my tail lights, dash lights, and front and side marker lights. But my headlights, fog lights, turn signals and hazards still work. So I consulted the wiring diagram, and this does make sense, since they are all connected. I checked the voltage coming out of the fuse when the switch is on and i get 12 volts. So I am losing connection some where before it breaks off into the different areas of the car, most likely near the fuse. Hopefully some one knows of a connector or some kind of fusible link under the dash. Please help.(not being able to drive the beast at night is disappointing)
1988 supra turbo. In process of modding:Roll cage, seats, dp, 3" intercooler, fuel upgrades, and turbo upgrades next.
tak2099 is offline   Reply With Quote
Old 05-14-2010, 04:30 AM   #2
If you've lost the front side markers the issue's in the fuse box. The front side markers and the climate control lighting break away before the harness leaves the box for the other items.
Old 05-14-2010, 04:44 AM   #3
tak2099
tak2099's Avatar
ouch, I guess I will be taking the fuse box out and see if I can see any bad connections. thanks
Old 05-14-2010, 07:51 PM   #4
TripleC
TripleC's Avatar
do a search on this subjhect and me - it should help you figure this situation out. I had the same problem Turned out to be 1 of the 3 Main power Lines running to the fuse box itself. google cygnusx/ MKIII supra
Look it up online and see the wiring diagrams for what you need to check.
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads
2 additional C12A turbo's(Extra)
