Old 05-14-2010, 04:44 AM   #1
batmmannn
batmmannn's Avatar
Default No Heat
Noticed today that I have no heat coming out of the heater. Car sat for 6 years and am just now getting it going. First thought was thermostat. 2nd thought was a temp sensor? Not sure. I have no history on this car and parked after purchase because of a bad starter I could not fix.
Would rather start looking into it now cause it's cold right now and also I would forget about it till winter then might not have time to fix it. Car seemed to run at correct temp, but have had little chance to test drive it cause I think I just snapped my timing belt. You all seem to know this car inside and out so I figure I would ask. Also I ran a search but saw nothing on the lack of heat listed.
Thanks so much!
Old 05-14-2010, 03:04 PM   #2
this has been posted very often. search "no heat" or "heater control valve"... I'm pretty sure it's posted in the Mkiii FAQ section too.
Old 05-14-2010, 03:38 PM   #3
batmmannn
batmmannn's Avatar
Default Thanks
I found some info. Thank You so much!
87 MK III turbo - AC & Heat Always On Problem robfab MKII Supra 0 08-04-2008 07:12 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
IC pipes and heat wrap questions. redmaro MKIII Supra 0 09-26-2007 08:00 AM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
heat getting into car sd88supra MKIII Supra 7 11-03-2006 12:47 AM
