#1 |
Hey Guys I know I am posting a lot please forgive me but I have all these Supras and that means all these problems. I have a video I made for you up on you tube, You guys Rock so let me know what you think this noise is OK?
The car is a black 87 N/A Auto No Mods about 170k on it. It started running sluggish and missing a bit when this noise started. I have driven it maybe 10 miles since this noise started. I have been told that it might be a rocker backing off or something broken in there. Thanks so Much! http://www.youtube.com/watch?v=93hEYr-V4jQ
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! |
#2 |
That could very well be rod knock or a valve problem. The one thing I do know is that is has no rockers since it is a Dual Overhead Cam Motor. Here is the valves and cams diagram....
http://www.cygnusx1.net/Supra/Librar...spx?F=1302&P=1 |
#3 |
Could it be the adjustment has come loose? I hope I don't find a rock in there or something my ex through in the motor. Hmmm, Maybe the car jumped time and the valve is slapping out of time?
#4 |
Doesn't sound like rod knock. There is also no adjusting to be done with the stock lifters. The only thing to adjust valve lash is with shims. It kind of sounds like an electrical arc. You should try and replace the plug wires, one might be cracked and arcing on to the head. Also I doubt that it jumped time I've never heard of it happening to anyone on these engines. To check timing set your crank to 0 deg btdc on compression stroke pull your camgear cover off and make sure both the stamped lines on the cam gears are pointing straight up. Then to make sure get a timing light and make sure your timing is at 10 deg btdc.
#5 |
I have to do research just to keep up with your responses. If it is arcing I should be able to see it in the dark correct? I agree I don't think it would idle so well if it jumped time, It will take me some time to figure out the other parts you spoke of. You think that sound is an arc? Wow what a concept! I saw a post about lining up the cam gear. Now if I can figure out where that is on the engine. If I have let this car sit so long because of a bad plug wire I am going to cry.... Thanks so much!
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! Last edited by batmmannn; 05-15-2010 at 03:42 AM. |
#6 |
to see the timing marks on the cam gears you take the panel off of the front of the engine that says 7m-ge. I actually just recently put a new engine in my jeep and it has coil on plug and its a little tricky to get on. So i put it on and thought it was on all 6 plugs so i started it up and it was idling shitty and had a miss and was making a loud arcing sound so i looked a little closer and realized the boot wasn't on the sixth sparkplug stuck it on and it ran perfect. As for seeing it in the dark I don't know if you would see it or not its worth a try.
valve noise | nailhead432 | MKIII Supra | 2 | 04-07-2010 03:48 PM |
Loud Clicking Noise!! | Cyto | MKIII Supra | 2 | 10-11-2009 03:34 AM |
Loud beeping noise | tannerjames | MKIII Supra | 0 | 09-07-2007 07:34 PM |
Valve Job On Head Now Car Wont Start? | MKIII shujin | MKIII Supra | 4 | 08-07-2006 02:16 AM |
tapping noise behind dash ? | supra887mgte | MKIII Supra | 2 | 10-21-2005 02:34 AM |
