Old 05-16-2010, 12:38 AM   #1
batmmannn
batmmannn's Avatar
Default How do you test your fuel pump?
Is there an easy way to test the fuel pump? My Red Supra has died. I hear no humming from the tank at all when the ignition is turned on even though I have my ear pressed to the tank. I found the thread on replacing it but I am wondering where is the best place to open up the system to see if it is pumping anything. My plugs are dry after a lot of cranking car suddenly died after sitting 6 years and on it's first test drive after a starter replacement.
Is it best to disconnect the fuel line before the filter and see if it can pump through on cranking? Can you open up the fuel regulator and see if it pumps and if so where is the fuel regulator on the car and what does it look like? I hear that is hard to get to. Please chime in and let me know.
Thanks so much, Scott
Old 05-16-2010, 12:49 AM   #2
I PMed you on how to bypass the ignition circuit to test the fuel pump... jumper the +B and FP connectors in the diagnostic box. If you can't hear it try actually measuring for pressure.
Old 05-16-2010, 12:59 AM   #3
batmmannn
batmmannn's Avatar
Default Hello Cre
I see in the manual where they say to do the bypass but how can I tell if I am getting fuel I need to see it coming out like out of a hose or something correct? I would have to get the tool to measure the pressure I was just hoping to find a way to see if it is working at all. Or are you saying do the jump and then go see if I can hear it running back at the tank? Oh and I take it there is no access panel under the seat for the pump like there is on the celica? Could it be a bad fuel relay? Thanks Scott
Old 05-16-2010, 01:17 AM   #4
Generally, you'll hear it flowing through the fuel rail. To really test it you should get a fuel compatible pressure gauge, disconnect the fuel pressure damper and connect the gauge to the rail there and see what the pressure is. I can't remember if you said this car was turbo or N/A, if it's N/A you need to have the AFM plugged in and you'll need to prop open the vane, otherwise the emergency fuel cut switch will prevent the fuel pump from getting power. You should also test the fuel pump relay and resistor.
Most of the trouble shooting proceedures you need to go though are located here:
http://www.cygnusx1.net/Supra/Librar....aspx?S=FI&P=1
Give it a thorough read.
Old 05-16-2010, 01:22 AM   #5
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=72
Here they recommend using the cold start injector's connection.
What manual are you using? Haynes?
Old 05-16-2010, 01:52 AM   #6
batmmannn
batmmannn's Avatar
Default Afm
Ok thanks I just read through the instructions. I am looking for the small box with the jumper to made in it. I found the box next to the fuse box. Since I don't have the tools to measure the pressure can I just open up the cold start line and then make the jump to see if it pumps fuel? Or should I disconnect the fuel line from the regulator and see if fuel pumps out of fuel line 2? Or as you said if I don't hear any return fuel passing then something is broke.
Thanks for your patience with me. I am not a pro at this by any means.
no power to fuel pump carcrzy920 Non-Generation Specific Questions 0 06-05-2009 05:51 PM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Fuel Pump or what? Drack57 MKII Supra 7 11-28-2005 07:33 PM
