Old 05-18-2010, 05:28 PM   #1
TehEl1te
TehEl1te's Avatar
TehEl1te is on a distinguished road
Default I need your opinion on why my car shuts off
Hey guys,
Ok, so my 89 Turbo Supra had a knock in it. We swapped an 88 Turbo motor in but just left the 89 harness in there. everything is running good and strong but once it warms up... it just shuts off and wont start again till it is cool. We took it to a shop and they said all the electrical is working and they replaced and checked all the hoses. They want to try the ECU... I had the extra ecu from the 88 motor i bought but apparantly its different so I need one to go with that 89 wiring harness... anyway, do you guys think the ECU is a likely reason it does that? Thanks in advance1
TehEl1te is offline   Reply With Quote
Old 05-19-2010, 04:10 PM   #2
FRISBEE
FRISBEE's Avatar
Is the starter the original unt?? Check the basics first battery post, cables ect. check for a voltage drop from the batt to the starter. check the voltage at the solenoid connector. check grounds too maybe you missed a ground wire. good luck.
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Old 05-20-2010, 12:09 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Since it cuts out when the engine gets warm I'm more inclined to believe you may have a problem with your igniter. You should check to see if you're getting spark next time it cuts out with an inline spark tester.
This could also explain why it fires once the engine has cooled down, since several times faulty igniters start having issues in extreme temps (hot or cold)
Old 05-20-2010, 02:28 AM   #4
nfa_automotive
nfa_automotive's Avatar
nfa_automotive is on a distinguished road
Originally Posted by TehEl1te View Post
Hey guys,
Did you use the 89 coolant temp sensor? The EPC shows they might be different.
1987 Supra Turbo Targa Blue 5spd 175K, 3" Exhaust from Turbo back, Lowered 1.5", 89 Steering Wheel and Climate Control, JDM Power Folding Mirrors, HKS Fan Controller, Greddy Turbo Timer, HKS EVCIII Boost Controller, Boost Gauge, Deleted Boost Gauge in Cluster for Volt, MKIV Non-Turbo wheels
1987 Supra N/A Coupe Blue Auto - Parts Car
1987 Supra Turbo Coupe Black 5spd - Bought with a spun bearing - RIP
1987 VW Jetta GTI Auto 89k
nfa_automotive is offline   Reply With Quote
Old 05-22-2010, 05:25 AM   #5
TehEl1te
TehEl1te's Avatar
I honestly do not know :\ I will check that. That is a good question
Old 06-03-2010, 05:20 AM   #6
btwilson86
Super Moderator
btwilson86's Avatar
Hey, so I saw that you're selling your car...
Did you get a chance to try the igniter? I'd hate to see someone lose a nice Supra like that (although if I had the money I'd jump all over it)
Anyway, I don't want you to give up without having the shop at least do a spark test after it cuts out. Any info you post on here could get us a step closer to helping you fix it, that is if you still want to deal with it.
EDIT: So I just reread that this is a TURBO supra, not a N/A (like I for some reason though), so I believe the function of the igniter would fall inside the CPS.
Old 06-03-2010, 05:23 AM   #7
TehEl1te
TehEl1te's Avatar
Bud thanks so much for the kind advice and nice words. I don't want to let her go I truly do need to have a vehicle that I can daily drive and if one of you amazing Supra guys can figure this problem out then I would very much like you to have it. Being a college student and on a low income atm... I just don't have the money to throw at her... even if she's almost done. This is definitely a car close to the finish line as far as completion goes. Figuring out this issue and some tlc and its gonna be a beauty.
Old 06-03-2010, 01:20 PM   #8
wstanek
wstanek's Avatar
wstanek is on a distinguished road
thats too bad! D=
wstanek is offline   Reply With Quote
wt... this cant be fuel cut..car shuts off 88Tsupra MKIII Supra 4 02-24-2007 07:31 AM
935? opinion??? koenigturbo Shops & Part Reviews 0 10-15-2006 02:39 AM
I need you guys opinion on this 1994 Supra Jiwon Non-Generation Specific Questions 2 06-14-2006 01:58 AM
Nedd honest opinion of value. Isphius MKIII Supra 3 05-08-2006 03:12 AM
Eibach lowering Springs: YOUR OPINION please sportriderseattle Non-Generation Specific Questions 0 02-21-2006 03:38 AM
